I am writing a VGA driver program in Verilog on a Spartan 3E (FPGA board Papilio one- 500k bundled with LogicStart MegaWIng). The frequency of the internal clock of Spartan 3E is 32MHz. But I need to generate 25Mhz clock to send Vsync and Hsync singnals. I tried to use the Digital Clock Manager (available in Xilinx Papilio boards) by following the tutorial at...
http://www.gadgetfactory.net/2010/08/dcm-digital-clock-manager-tutorial/
However, the tutorial explains by generating a code in VHDL. I followed the same steps with the only change that, I opted for "Verilog" while choosing the language of the code. However the code generated in my case is structurally different from that in tutorial and I am unable to generate a 25 Mhz clock.
I need to know how to use the DCM feature of Xilinx Papilio boards with Verilog to generate 25 Mh clock from internal 32Mhz clock. How to generate the instantiation code and then how to use it in your .v file containing the code that uses the 25Mhz clock?
Addition
I am using ISE Design Suite 14.7. The code that gets generated with the DCM feature used with Verilog is as follows.
// Instantiate the module
DCM32to50 instance_name (
.CLKIN_IN(CLKIN_IN),
.CLKFX_OUT(CLKFX_OUT),
.CLKIN_IBUFG_OUT(CLKIN_IBUFG_OUT),
.CLK0_OUT(CLK0_OUT)
I don't know how to use this in my code and that 25Mhz is produced at which pin.
