I am writing a VGA driver program in Verilog on a Spartan 3E (FPGA board Papilio one- 500k bundled with LogicStart MegaWIng). The frequency of the internal clock of Spartan 3E is 32MHz. But I need to generate 25Mhz clock to send Vsync and Hsync singnals. I tried to use the Digital Clock Manager (available in Xilinx Papilio boards) by following the tutorial at...
http://www.gadgetfactory.net/2010/08/dcm-digital-clock-manager-tutorial/
However, the tutorial explains by generating a code in VHDL. I followed the same steps with the only change that, I opted for "Verilog" while choosing the language of the code. However the code generated in my case is structurally different from that in tutorial and I am unable to generate a 25 Mhz clock.
I need to know how to use the DCM feature of Xilinx Papilio boards with Verilog to generate 25 Mh clock from internal 32Mhz clock. How to generate the instantiation code and then how to use it in your .v file containing the code that uses the 25Mhz clock?
Addition
I am using ISE Design Suite 14.7. The code that gets generated with the DCM feature used with Verilog is as follows.
// Instantiate the module
DCM32to50 instance_name (
    .CLKIN_IN(CLKIN_IN),
    .CLKFX_OUT(CLKFX_OUT),
    .CLKIN_IBUFG_OUT(CLKIN_IBUFG_OUT),
    .CLK0_OUT(CLK0_OUT)
I don't know how to use this in my code and that 25Mhz is produced at which pin.
    \$\begingroup\$ What version of ISE are you using? What do you mean when you say the code it generates is "structurally different"? Could you add to your question the instantiation template for your clocking wizard output? \$\endgroup\$
    – stanri
    Commented May 30, 2014 at 20:13
    \$\begingroup\$ Have you tried using the xilinx core generator in ISE? You can use it to set up the DCM and then copy the code from the instantiation template that it generates \$\endgroup\$
    – Will
    Commented May 30, 2014 at 21:14
  • \$\begingroup\$ @Stacey I have added the extra details to my question. \$\endgroup\$
    – Kanupriya
    Commented Jun 1, 2014 at 8:25
  • \$\begingroup\$ @Will the instantiation template that it generates is added to my question. I don't know how to use it in my code. \$\endgroup\$
    – Kanupriya
    Commented Jun 1, 2014 at 8:26
The Instanitation template gives you an example of how to use the core in your project. All you need to do is paste it into your verilog file.
                         ^ Change the signals in brackets to your signals
     ^ You don't need to change the port names
    .CLK0_OUT(CLK0_OUT)
To help you match it up with the tutorial, in VHDL, it looks like this:
DCM32to50_i : DCM32to50
port map (
CLKIN_IN        => CLKIN_IN,
CLKFX_OUT       => CLKFX_OUT,
CLKIN_IBUFG_OUT => CLKIN_IBUFG_OUT,
CLK0_OUT        => CLK0_OUT);
                         ^ Signal name you can make what you want.
  ^ Port name doesn't change
CLKIN_IN is your input 32 Mhz clock
CLKFX_OUT is the new 25 Mhz clock
CLKIN_IBUFG_OUT is a buffered version of your 32 Mhz clock
CLK0_OUT is your input clock at 0 phase (basically your input clock again).
'Instantiation template' is just an fancy way of saying that it is giving you a code example.
Verilog names signals work like .input_or_output_name( my_signalname) Like .clock(my_clock_signal) So their instantiation template looks like this:
//  DCM32to50 is the type of thing you want one of, 'instance_name' is what it will be called
//  in the original instantiation template, I've changed it to 'my_dcm'
DCM32to50 my_dcm ( .CLKIN_IN(CLKIN_IN), // Clock input (32MHz)
               .CLKFX_OUT(CLKFX_OUT),  // Clock fx output
               .CLKIN_IBUFG_OUT(CLKIN_IBUFG_OUT), // loop through of the clock you put in
               .CLK0_OUT(CLK0_OUT) ); // Clock 0
You can check in core generator what clock fx, and clock 0 are. I expect clock 0 is your 25Mhz clock.
So if your top level looks like this now
module toplevel(
   input wire clk_in,
   output reg [7:0] output
always @(posedge clk_in)
begin
// do some stuff
end
endmodule
You can put the dcm in like this
module toplevel(
   input wire clk_in,
wire slow_clk, clk_fx, clk_loopthrough;
DCM32to50 my_dcm ( .CLKIN_IN(clk_in), // Clock input (32MHz)
                  .CLKFX_OUT(clk_fx),  // Clock fx output
                  .CLKIN_IBUFG_OUT(clk_loopthrough), // loop through of the clock you put in
                  .CLK0_OUT(slow_clk) ); // Clock 0
always @(posedge slow_clk) //! NOTE THIS IS NOW USING THE CLOCK FROM THE DCM
begin
// do some stuff
end
endmodule
    \$\begingroup\$ ClkFX is the 25 Mhz clock. On the older wizards, If I remember correctly, clk0_out is the input clk at 0 phase. \$\endgroup\$
    – stanri
    Commented Jun 2, 2014 at 11:25
