When you set a signal in Verilog to z
, you're allowing some external device to drive it high or low. In the physical implementation, if there isn't any actual device driving the net, then you're allowing random static electricity to drive it to either 0 or 1. You shouldn't expect to see an actual "Z" state in the physical circuit.
On top of which, in comments, you said this was implemented on an Altera FPGA. Recent FPGAs (since 1995 or so) generally don't implement actual tri-state logic on internal nets. If you design a multiply connected bus with tristate in your Verilog, the physical implementation will use multiplexers to approximate the effect of the tristate logic. But there will never be an actual moment when the net is un-driven in the actual FPGA.
Since you didn't specify whether you wanted a 0 or a 1 driven on those nets when your main driver applied "z", the synthesis tool was free to drive them to either 0 or 1 and had no way of knowing which you wanted.
dataread
is 5-bit wide, but you assign only 4 bits of it. \$\endgroup\$dataread
lines? \$\endgroup\$
