I have to use combinational logic to write Verilog for a circuit schematic. However, my output registers, CLK1 and CLK2, do not change and are stuck at the initial values. What is causing this bug? Here is the code and output:
//Verilog HDL for "HW8", "ClockCircuit" "functional"
`resetall
`celldefine
`delay_mode_path
`timescale 1ns / 10ps
module ClockCircuit (
input wire CLKin,
output reg CLK1,
output reg CLK2
initial begin
CLK1 = 0;
CLK2 = 0;
end
// Intermediate signals
wire inv_output;
wire nor1_output;
wire nor2_output;
// Instantiate the inverter
inv_1 inv (
CLKin,
inv_output
// Instantiate the first NOR gate
nor_2 nor16 (
CLKin,
nor2_output,
nor1_output
// Instantiate the second NOR gate
nor_2 nor2 (
nor1_output,
inv_output,
nor2_output
// Drive the outputs using procedural blocks
always @(posedge CLKin) begin
CLK1 <= nor1_output;
CLK2 <= nor2_output;
end
endmodule
`endcelldefine
The circuit I'm trying to create is here:
