// S23_ALU_control_tb.v
// Testbench for MIPS ALU Control Unit
`timescale 1ns / 1ps
module test_ALU_CTL;
   parameter finishtime = 100;
   module ALU_control (
    output reg [3:0] ALUctl,
    input [1:0] ALUOp,
    input [5:0] funct
   always @(*)
   begin
       case ({ALUOp, funct})
           6'b00_000000: ALUctl = 4'b0010;   // lw
           6'b01_000000: ALUctl = 4'b0110;   // beq
           6'b10_000000:                     // R-type
               case (funct)
                   6'b100000: ALUctl = 4'b0010;   // add
                   6'b100010: ALUctl = 4'b0110;   // sub
                   6'b100100: ALUctl = 4'b0000;   // and
                   6'b100101: ALUctl = 4'b0001;   // or
                   6'b101010: ALUctl = 4'b0111;   // slt
                   6'b100111: ALUctl = 4'b1100;   // nor
                   6'b100110: ALUctl = 4'b1101;   // xor
                   default: ALUctl = 4'b1111;      // default value
               endcase
       endcase
   end
  initial $monitor($time, " ALUOp=%b funct=%b ALUctl=%b",
                    ALUOp, funct, ALUctl);
endmodule // ALU_control
When I run the code I get the below error:
TOOL:   xmverilog   23.09-s004: Started on Apr 16, 2024 at 23:04:20 CDT
xmverilog(64): 23.09-s004: (c) Copyright 1995-2023 Cadence Design Systems, Inc.
file: S23_ALU_control_tb-33.v
xmvlog: *E,EXPENM (S23_ALU_control_tb-33.v,13|8): expecting the keyword 'endmodule' [12.1(IEEE)].
    module worklib.test_ALU_CTL:v
        errors: 1, warnings: 0
xmvlog: *W,INTOVF (S23_ALU_control_tb-33.v,22|22): bit overflow during conversion from text [2.5(IEEE)] (6 bits).
xmvlog: *W,INTOVF (S23_ALU_control_tb-33.v,23|22): bit overflow during conversion from text [2.5(IEEE)] (6 bits).
xmvlog: *W,INTOVF (S23_ALU_control_tb-33.v,24|22): bit overflow during conversion from text [2.5(IEEE)] (6 bits).
    module worklib.ALU_control:v
        errors: 0, warnings: 3
xmverilog: *E,VLGERR: An error occurred during parsing.  Review the log file for errors with the code *E and fix those identified problems to proceed.  Exiting with code (status 1).
TOOL:   xmverilog   23.09-s004: Exiting on Apr 16, 2024 at 23:04:21 CDT  (total: 00:00:01)
I am new to Verilog. Can anyone explain these errors?
  • \$\begingroup\$ Do you think that 6'b00_000000 perhaps should be 8'b00_000000? \$\endgroup\$ Commented Apr 17 at 4:35
  • \$\begingroup\$ did you read the error? ... what is it telling you to do? \$\endgroup\$
    – jsotola
    Commented Apr 17 at 4:38
  • \$\begingroup\$ it wants me to insert the keyword endmodule to the code and the line for the ALUctl = 4'b0010- I could be wrong - still learning \$\endgroup\$
    – Zelda
    Commented Apr 17 at 4:45
  • \$\begingroup\$ I fixed the line for the bits and added the 8 bits that correspond to the value assigned but now i get a parsing error: \$\endgroup\$
    – Zelda
    Commented Apr 17 at 4:53
  • \$\begingroup\$ I see endmodule the end of the code but it is still not parsing it. Do i need to remove something? | xmvlog: *E,EXPENM (S23_ALU_control_tb-33.v,13|8): expecting the keyword 'endmodule' [12.1(IEEE)]. module worklib.test_ALU_CTL:v errors: 1, warnings: 0 module worklib.ALU_control:v errors: 0, warnings: 0 xmverilog: *E,VLGERR: An error occurred during parsing. Review the log file for errors with the code *E and fix those identified problems to proceed. Exiting with code (status 1). TOOL: xmverilog 23.09-s004: Exiting on Apr 16, 2024 at 23:50:22 CDT (total: 00:00:01) \$\endgroup\$
    – Zelda
    Commented Apr 17 at 4:54
The error message (*E) occurs because you should create 2 separate modules, not one inside another. Then you should place an instance of the design module inside the testbench module. Here is one way to do so:
 input [1:0] ALUOp,
 input [5:0] funct
   always @(*)
   begin
               case (funct)
               endcase
       endcase
   end
    reg [1:0] ALUOp;
    reg [5:0] funct;
    wire [3:0] ALUctl;
ALU_control dut (
    .ALUOp   (ALUOp),
    .funct   (funct),
    .ALUctl  (ALUctl)
endmodule
Refer to How to instantiate a module.
The warning messages (*W) are self-evident. The constant (6'b10_000000) has 8 bits to the right of the b, but you specified a bit width of 6 to the left of the b. To specify a width of 8, use:
8'b10_000000
Making those changes allows the code to compile without errors or warnings.
  • \$\begingroup\$ Thank you. I realized i had to create 2 files to run the code and this is what i was working on last night. Thank you for pointing out it could be also be handled in one file. \$\endgroup\$
    – Zelda
    Commented Apr 17 at 14:49
