// S23_ALU_control_tb.v
// Testbench for MIPS ALU Control Unit
`timescale 1ns / 1ps
module test_ALU_CTL;
parameter finishtime = 100;
module ALU_control (
output reg [3:0] ALUctl,
input [1:0] ALUOp,
input [5:0] funct
always @(*)
begin
case ({ALUOp, funct})
6'b00_000000: ALUctl = 4'b0010; // lw
6'b01_000000: ALUctl = 4'b0110; // beq
6'b10_000000: // R-type
case (funct)
6'b100000: ALUctl = 4'b0010; // add
6'b100010: ALUctl = 4'b0110; // sub
6'b100100: ALUctl = 4'b0000; // and
6'b100101: ALUctl = 4'b0001; // or
6'b101010: ALUctl = 4'b0111; // slt
6'b100111: ALUctl = 4'b1100; // nor
6'b100110: ALUctl = 4'b1101; // xor
default: ALUctl = 4'b1111; // default value
endcase
endcase
end
initial $monitor($time, " ALUOp=%b funct=%b ALUctl=%b",
ALUOp, funct, ALUctl);
endmodule // ALU_control
When I run the code I get the below error:
TOOL: xmverilog 23.09-s004: Started on Apr 16, 2024 at 23:04:20 CDT
xmverilog(64): 23.09-s004: (c) Copyright 1995-2023 Cadence Design Systems, Inc.
file: S23_ALU_control_tb-33.v
xmvlog: *E,EXPENM (S23_ALU_control_tb-33.v,13|8): expecting the keyword 'endmodule' [12.1(IEEE)].
module worklib.test_ALU_CTL:v
errors: 1, warnings: 0
xmvlog: *W,INTOVF (S23_ALU_control_tb-33.v,22|22): bit overflow during conversion from text [2.5(IEEE)] (6 bits).
xmvlog: *W,INTOVF (S23_ALU_control_tb-33.v,23|22): bit overflow during conversion from text [2.5(IEEE)] (6 bits).
xmvlog: *W,INTOVF (S23_ALU_control_tb-33.v,24|22): bit overflow during conversion from text [2.5(IEEE)] (6 bits).
module worklib.ALU_control:v
errors: 0, warnings: 3
xmverilog: *E,VLGERR: An error occurred during parsing. Review the log file for errors with the code *E and fix those identified problems to proceed. Exiting with code (status 1).
TOOL: xmverilog 23.09-s004: Exiting on Apr 16, 2024 at 23:04:21 CDT (total: 00:00:01)
I am new to Verilog. Can anyone explain these errors?
6'b00_000000
perhaps should be8'b00_000000
? \$\endgroup\$
