While I use the internal clock for DCM clkin input I am getting clk0 as perfect frequency of output same as internal clock but not in remaining o/p pins. I changed from previous coding like this and also schematic as below.
module dcm_clockverilog(clk,rst,clkdiv,clk0,clk2x,locked,clock);
input clk;
input rst;
output clkdiv;
output clk0;
output clk2x;
output locked;
output  clock;
wire clk0;
wire clk2x;
wire locked;
wire clkdiv;
reg [7:0] count=0;
reg clock=0;
dcmm instance_name (
    .CLKIN_IN(clock),
    .RST_IN(rst),
    .CLKDV_OUT(clkdiv),
    .CLK0_OUT(clk0),
    .CLK2X_OUT(clk2x),
    .LOCKED_OUT(locked)
always @(posedge clk)
begin
   count <=count+1;
if(count<=9)
   clock<=0;
if(count>=10)
   clock<=1;
if(count>=19)
   count<=0;
end
endmodule
//---------------------------------------------plan ahead
# PlanAhead Generated physical constraints
NET "clk" LOC = P57;//-- (GCLK)
NET "clk0" LOC = P7;//--(I/O)
NET "clk2x" LOC = P8;//--(I/O)
NET "clkdiv" LOC = P10;//--(I/O)
NET "clock" LOC = P11;//--(THIS CLOCK I ASSIGN AS INPUT FOR DCM CLKIN) )
NET "locked" LOC = P12;//--(I/O)
NET "rst" LOC = P18;//--(INPUT SWITCH)
You don't have CLKFB connected - I'm surprised you get anything!
From the Spartan 3 userguide, UG331
CLKFB Clock feedback input to DCM. The feedback input is required unless the Digital Frequency Synthesis outputs, CLKFX or CLKFX180, are used stand-alone. The source of the CLKFB input must be the CLK0 or CLK2X output from the DCM and the CLK_FEEDBACK must be set to 1X or 2X accordingly. The feedback point ideally includes the delay added by the clock distribution network, either internally or externally.
  • \$\begingroup\$ Mr martin thompson pls see that schematic i connected clk0 output as clkfb input fro DCM WITH i/o BUFFER .... \$\endgroup\$
    – user39051
    Commented Mar 25, 2014 at 7:44
  • \$\begingroup\$ The schematic is unreadable, so I was going by what your code says. If your code has the feedback in it, please post that so we are not looking for problems in the wrong place. \$\endgroup\$ Commented Mar 25, 2014 at 10:09
  • \$\begingroup\$ Mr martin thompson thanks for your guidance .......... \$\endgroup\$
    – user39051
    Commented Mar 26, 2014 at 4:19
