this sub-code that read the selection line s4-s1 and take the summation of a,b in the selection line =0000, When running this code in ISE project negotiator it gives syntax error tell " Syntax error near "=" " in the line z=0 in the if statement
can you tell me why ?
module one1(a,b,s1,s2,s3,s4,f );
  input s1,s2,s3,s4;
  input [3:0] a,b;
  output reg [3:0] f;
  reg  z,n,c;
  //0000
  if ({s4,s3,s2,s1} == 4'b0000)
  begin
    assign {c,f}= a+b;
    if (f==0)
      z=1;         //here is the error
    else z=0;
    n=f[3];
  end
endmodule
Two problems:
  1. You need to wrap an always block around your combinational logic. Something like always @* begin
then put your if statement in there.
  1. You can't assign a wire inside an always block. you need a reg.
  • \$\begingroup\$ "you need a reg."... or move the assign statement outside the if block. \$\endgroup\$
    – The Photon
    Commented Apr 11, 2015 at 18:44
