Alex has already written a lot about infering the DSP slices. My answer focuses only on:
Where do I find the RAW DSP instantiating template? I have been googling for it, but I didn't find a definitive guide to it.
The template can be found in the Libraries Guide for HDL Designs from Xilinx. For your Spartan-6 FPGA it is UG615. The description of the DSP48A1 slices can be found on page 92 ff.. The VHDL instantiation template is for example:
Library UNISIM;
use UNISIM.vcomponents.all;
-- DSP48A1: 48-bit Multi-Functional Arithmetic Block
-- Spartan-6
-- Xilinx HDL Libraries Guide, version 14.7
DSP48A1_inst : DSP48A1
generic map (
A0REG => 0, -- First stage A input pipeline register (0/1)
A1REG => 1, -- Second stage A input pipeline register (0/1)
B0REG => 0, -- First stage B input pipeline register (0/1)
B1REG => 1, -- Second stage B input pipeline register (0/1)
CARRYINREG => 1, -- CARRYIN input pipeline register (0/1)
CARRYINSEL => "OPMODE5", -- Specify carry-in source, "CARRYIN" or "OPMODE5"
CARRYOUTREG => 1, -- CARRYOUT output pipeline register (0/1)
CREG => 1, -- C input pipeline register (0/1)
DREG => 1, -- D pre-adder input pipeline register (0/1)
MREG => 1, -- M pipeline register (0/1)
OPMODEREG => 1, -- Enable=1/disable=0 OPMODE input pipeline registers
PREG => 1, -- P output pipeline register (0/1)
RSTTYPE => "SYNC" -- Specify reset type, "SYNC" or "ASYNC"
port map (
-- Cascade Ports: 18-bit (each) output: Ports to cascade from one DSP48 to another
BCOUT => BCOUT, -- 18-bit output: B port cascade output
PCOUT => PCOUT, -- 48-bit output: P cascade output (if used, connect to PCIN of another DSP48A1)
-- Data Ports: 1-bit (each) output: Data input and output ports
CARRYOUT => CARRYOUT, -- 1-bit output: carry output (if used, connect to CARRYIN pin of another
-- DSP48A1)
CARRYOUTF => CARRYOUTF, -- 1-bit output: fabric carry output
M => M, -- 36-bit output: fabric multiplier data output
P => P, -- 48-bit output: data output
-- Cascade Ports: 48-bit (each) input: Ports to cascade from one DSP48 to another
PCIN => PCIN, -- 48-bit input: P cascade input (if used, connect to PCOUT of another DSP48A1)
-- Control Input Ports: 1-bit (each) input: Clocking and operation mode
CLK => CLK, -- 1-bit input: clock input
OPMODE => OPMODE, -- 8-bit input: operation mode input
-- Data Ports: 18-bit (each) input: Data input and output ports
A => A, -- 18-bit input: A data input
B => B, -- 18-bit input: B data input (connected to fabric or BCOUT of adjacent DSP48A1)
C => C, -- 48-bit input: C data input
CARRYIN => CARRYIN, -- 1-bit input: carry input signal (if used, connect to CARRYOUT pin of another
-- DSP48A1)
D => D, -- 18-bit input: B pre-adder data input
-- Reset/Clock Enable Input Ports: 1-bit (each) input: Reset and enable input ports
CEA => CEA, -- 1-bit input: active high clock enable input for A registers
CEB => CEB, -- 1-bit input: active high clock enable input for B registers
CEC => CEC, -- 1-bit input: active high clock enable input for C registers
CECARRYIN => CECARRYIN, -- 1-bit input: active high clock enable input for CARRYIN registers
CED => CED, -- 1-bit input: active high clock enable input for D registers
CEM => CEM, -- 1-bit input: active high clock enable input for multiplier registers
CEOPMODE => CEOPMODE, -- 1-bit input: active high clock enable input for OPMODE registers
CEP => CEP, -- 1-bit input: active high clock enable input for P registers
RSTA => RSTA, -- 1-bit input: reset input for A pipeline registers
RSTB => RSTB, -- 1-bit input: reset input for B pipeline registers
RSTC => RSTC, -- 1-bit input: reset input for C pipeline registers
RSTCARRYIN => RSTCARRYIN, -- 1-bit input: reset input for CARRYIN pipeline registers
RSTD => RSTD, -- 1-bit input: reset input for D pipeline registers
RSTM => RSTM, -- 1-bit input: reset input for M pipeline registers
RSTOPMODE => RSTOPMODE, -- 1-bit input: reset input for OPMODE pipeline registers
RSTP => RSTP -- 1-bit input: reset input for P pipeline registers
