6
This question explains how to use Verilog parameters to combine constants from different modules at compile time. I am wondering if it is also possible to use conditional statements to modify parameter values at compile time.
Specifically, if the calculated total of the parameter values exceeds some maxLength, I want the parameter to 'wrap around' maxLength and be left with the remainder instead.
Pseudo-code example:
module toplevel {
    defparam myPole.offset = 95;
    pole myPole();
module pole {
    parameter offset = 0; // default value, overwritten by 95
    localparam x = 1;
    localparam y = 2;
    localparam z = 3;
    localparam maxLength = 100;
    localparam transitionConst = x + y + z + offset; // total is 101, this works as expected
    if(transitionConst > maxLength){
        transitionConst = transistionConst - maxLength;
    } // transitionConst should wrap around 100, and be left with 1
I looked at compiler directive tutorials at asic-world.com and TestBench.in, but the only if statements they describe are ifdefs. So, I suspect that Verilog does not support generic compile-time conditional statements. Is there a different approach I could use to accomplish this?
(P.S. I've seen Verilog Q&A on both EE.SE as well as StackOverflow. Which is the more appropriate community?)
  • \$\begingroup\$ Whatever you do, do not use defparam. It is strongly discouraged and the standardization body would loved to drop it if they could. \$\endgroup\$
    – Oldfart
    Commented Feb 20, 2019 at 18:41
    \$\begingroup\$ I think this community is more appropriate. Stackoverflow describes itself as "Q&A for professional and enthusiast programmers", which is more SW centric, whereas, while ASIC/FPGA design uses SW to describe the HW, it isn't the same as writing SW in terms of OOP aspects. ASIC/FPGA SV verification space, on the other hand, is OOP, but because it is still "HW engineering", I think you would be hard-pressed to get much help on stackoverflow for SV, and more likely to get it here. I could be wrong, but I would come here first. \$\endgroup\$
    – CapnJJ
    Commented Feb 20, 2019 at 20:03
7
You can use the conditional operator condition ? true_expression : false_expression as long as everything within the expression is a parameter or literal constant.
localparam transitionConst = (transitionConst <=  maxLength) ? x + y + z + offset : transistionConst - maxLength;
You can also use functions to define parameters, as long as all the function inputs are parameters or constants as well.
    \$\begingroup\$ That is also known as a Ternary operator/statement if you want additional information \$\endgroup\$
    – Veskah
    Commented Feb 20, 2019 at 21:27
You can do it it in your script (e.g. makefile) at compile time using maxLength as an input to an if-then-else statement that assigns a parameter value. Then pass these values using whatever mechanism the simulator you are using requires for you to specify the value on the command line (-g for Questa). Thus, for Questa/Modelsim, you would build your command line adding -g <name>=<value> to your vsim command. Look at command line reference for the details.
