I have been learning Verilog and Vivado at school, and I am now very confused by the usage of busses and arrays. Can anyone clarify the following?
- What is the difference between an array and a bus?
- During declaration, a bus would look something like
reg [9:0]data
while an array would bereg data[9:0]
. Is there a subtle (or not-so-subtle) difference in how the language handles these cases? - Why are is a bus declared with and index in front of the variable name, but referenced with an index behind? For instance,
data[3]
would work regardless of whetherdata
is declared as an array or bus.
- I have found it is possible (although confusing) to create declarations such as
reg [4:0]busArray[3:0]
, which would create 4x 5-bit registers.- Is this bad practice?
- How is this different from 2d array declared
reg arrayArray[4:0][3:0]
- When should I use a bus and when should I use an array?
I have a few other related questions as well...
- When you have a declaration like
reg [7:0]data[1023:0]
, is is possible to access individual bits and ranges?- I have had trouble accessing ranges of bits. For instance,
data[7:0][4]
seems to work, butdata[0][255:0]
ordata[3:1][512:64]
results in a syntax error. Are there rules about how you can access elements in busses and arrays?
- Is is possible to declare a multi-dimensional bus? (something like
reg [15:0][8:0]data
) - Is there a way to type cast an array so that it is treated like a bus? This could be useful in order to pass an array into a module designed to accept a bus.
