I at the moment trying to reverse engineer something i made a long time ago but never understood why it is running so slowly.
I have a Zybo board, with an Zynq 7010s chip ons which has dual cortex-A9 processor and a FPGA tightly compacted together.
On the CPU side i made a game, which for each iteration generate an array of decsribing the pixel value of the game image.
=> first question => this array is pretty large, and i am bit unsure where this variable would be stored?.. I just created a variable that had this value.
Next the game image had to be displayed on vga port, for which i how to transfer the data from the PS to PL side. I used the AXI DMA, and transfered it like this:
void send_data(char c_map, u32 target){
//xil_printf("\r\nStarting sending data\r\n");
/* Initialize the XAxiDma device.
CfgPtr = XAxiDma_LookupConfig(DMA_DEV_ID);
if (!CfgPtr) {
xil_printf("No config found for %d\r\n", DMA_DEV_ID);
//return XST_FAILURE;
Status = XAxiDma_CfgInitialize(&AxiDma, CfgPtr);
if (Status != XST_SUCCESS) {
xil_printf("Initialization failed %d\r\n", Status);
if(XAxiDma_HasSg(&AxiDma)){
xil_printf("Device configured as SG mode \r\n");
//Value = 0b11110000000000000000000101000000;
if(c_map == WALL){
//bbbbggggrrrr
Value = 0b11111111111100000000000000000000;
//Value = 0b00000100000000000000000000000000;
Value = Value + target;
}else if(c_map == BALL){
//Value = 0b10000000000000000000000000000000;
Value = 0b00000000111100000000000000000000;
}else{
Value = 0b00000000000000000000000000000000;
for(Index = 0; Index < MAX_PKT_LEN; Index ++) {
TxBufferPtr[Index] = Value;
Xil_DCacheFlushRange((UINTPTR)TxBufferPtr, MAX_PKT_LEN);
Status = XAxiDma_SimpleTransfer(&AxiDma,(UINTPTR) TxBufferPtr,
MAX_PKT_LEN, XAXIDMA_DMA_TO_DEVICE);
xil_printf("No XST_SUCCESS \r\n");
while (XAxiDma_Busy(&AxiDma,XAXIDMA_DMA_TO_DEVICE)) {} //wait
In the PL i create a block ram as such
type RAM is array (0 to ADDR_WIDTH+1) of std_logic_vector (DATA_WIDTH-1 downto 0);
signal mem : RAM := (others => (others => '1'));
Which supposedly should be a block ram, and then inside my VGA driver fill in my memeory block with the data received as input from the zynq as such.
MEM_READ:
process(clk)
begin
if (rising_edge(clk)) then
if ((hSyncCounter > hBackPorch) and (hSyncCounter <= hBackPorch+hDataLen)) then
mem(conv_integer(data(19 downto 0))) <= data(31 downto 20);--"111100000000";
end if;
end if;
end process;
Data being an input signal. 31 downto 20 consist of the RGB value of the pixel. and 19 downto 0 is the adress of i gave from the C.
19 downto 0 is just the grid position in the image and not a specific ram location or something like that, but where is the mem
I create in the PL stored, or made of? Is it just a big giant mux?
