module Cordic_multiplier_16bit(Xin,Yin,Zin,clk,Xn,Yn,Zn);
input [15:0]Xin,Yin,Zin;
output reg [15:0]Xn = 16'b0,Yn= 16'b0,Zn= 16'b0;
input clk;
wire [15:0]X,Y,Z;
//output variables for each stage
wire[15:0]w1,w4,w7,w10,w13,w16,w19,w22,w25,w28,w31,w34,w37,w40,w43,w46;
wire[15:0]w2,w5,w8,w11,w14,w17,w20,w23,w26,w29,w32,w35,w38,w41,w44,w47;
wire[15:0]w3,w6,w9,w12,w15,w18,w21,w24,w27,w30,w33,w36,w39,w42,w45,w48;
wire[15:0]R1,R4,R7,R10,R13,R16,R19,R22,R25,R28,R31,R34,R37,R40,R43,R46;
wire[15:0]R2,R5,R8,R11,R14,R17,R20,R23,R26,R29,R32,R35,R38,R41,R44,R47;
wire[15:0]R3,R6,R9,R12,R15,R18,R21,R24,R27,R30,R33,R36,R39,R42,R45,R48;
//LUT table
reg [15:0]LUT1=16'b0001000110010011;
reg [15:0]LUT2=16'b0000100000101100;
reg [15:0]LUT3=16'b0000010000000100;
reg [15:0]LUT4=16'b0000001000000000;
reg [15:0]LUT5=16'b0000000100000000;
reg [15:0]LUT6=16'b0000000010000000;
reg [15:0]LUT7=16'b0000000001000000;
reg [15:0]LUT8=16'b0000000000100000;
reg [15:0]LUT9=16'b0000000000010000;
reg [15:0]LUT10=16'b0000000000001000;
reg [15:0]LUT11=16'b0000000000000100;
reg [15:0]LUT12=16'b0000000000000010;
reg [15:0]LUT13=16'b0000000000000001;
reg [15:0]LUT14=16'b0000000000000001;
reg_16bit REG01(X,Xin,clk);
reg_16bit REG02(Y,Yin,clk);//storing Xin,Yin,Zin values in X,Y,Z
reg_16bit REG03(Z,Zin,clk);
//1st stage
adder_sub_block ASB1(Y[15:0],X[15:0],~Y[15],w1);
reg_16bit REG1(R1,w1,clk);
adder_sub_block ASB2(Y[15:0],X[15:0],~Y[15],w2);
reg_16bit REG2(R2,w2,clk);
adder_sub_block ASB3(Z[15:0],LUT1,Y[15],w3);
reg_16bit REG3(R3,w3,clk);
//2nd stage
adder_sub_block ASB4(R1,Y[15:0]>>>1,~R2[15],w4);
reg_16bit REG4(R4,w4,clk);
adder_sub_block ASB5(R2,X[15:0]>>>1,~R2[15],w5);
reg_16bit REG5(R5,w5,clk);
adder_sub_block ASB6(R3[15:0],LUT2,R2[15],w6);
reg_16bit REG6(R6,w6,clk);
//3rd stage
adder_sub_block ASB7(R4,Y[15:0]>>>2,~R5[15],w7);
reg_16bit REG7(R7,w7,clk);
adder_sub_block ASB8(R5,X[15:0]>>>2,~R5[15],w8);
reg_16bit REG8(R8,w8,clk);
adder_sub_block ASB9(R6[15:0],LUT3,R5[15],w9);
reg_16bit REG9(R9,w9,clk);
//4th stage
adder_sub_block ASB10(R7,Y[15:0]>>>3,~R8[15],w10);
reg_16bit REG10(R10,w10,clk);
adder_sub_block ASB11(R8,X[15:0]>>>3,~R8[15],w11);
reg_16bit REG11(R11,w11,clk);
adder_sub_block ASB12(R9[15:0],LUT4,R8[15],w12);
reg_16bit REG12(R12,w12,clk);
//5th stage
adder_sub_block ASB13(R10,Y[15:0]>>>4,~R11[15],w13);
reg_16bit REG13(R13,w13,clk);
adder_sub_block ASB14(R14,X[15:0]>>>4,~R11[15],w14);
reg_16bit REG14(R14,w14,clk);
adder_sub_block ASB15(R15[15:0],LUT4,R11[15],w15);
reg_16bit REG15(R15,w15,clk);
//6th stage
adder_sub_block ASB16(R16,Y[15:0]>>>5,~R14[15],w16);
reg_16bit REG16(R16,w16,clk);
adder_sub_block ASB17(R17,X[15:0]>>>5,~R14[15],w17);
reg_16bit REG17(R17,w17,clk);
adder_sub_block ASB18(R18[15:0],LUT5,R11[15],w18);
reg_16bit REG18(R18,w18,clk);
//7th stage
adder_sub_block ASB19(R19,Y[15:0]>>>6,~R17[15],w19);
reg_16bit REG19(R19,w19,clk);
adder_sub_block ASB20(R20,X[15:0]>>>6,~R17[15],w20);
reg_16bit REG20(R20,w20,clk);
adder_sub_block ASB21(R21[15:0],LUT6,R17[15],w21);
reg_16bit REG21(R21,w21,clk);
//8th stage
adder_sub_block ASB22(R22,Y[15:0]>>>7,~R20[15],w22);
reg_16bit REG22(R22,w22,clk);
adder_sub_block ASB23(R23,X[15:0]>>>7,~R20[15],w23);
reg_16bit REG23(R23,w23,clk);
adder_sub_block ASB24(R24[15:0],LUT7,R20[15],w24);
reg_16bit REG24(R24,w24,clk);
//9th stage
adder_sub_block ASB25(R25,Y[15:0]>>>8,~R23[15],w25);
reg_16bit REG25(R25,w25,clk);
adder_sub_block ASB26(R26,X[15:0]>>>8,~R23[15],w26);
reg_16bit REG26(R26,w26,clk);
adder_sub_block ASB27(R27[15:0],LUT8,R23[15],w27);
reg_16bit REG27(R27,w27,clk);
//10th stage
adder_sub_block ASB28(R28,Y[15:0]>>>9,~R26[15],w28);
reg_16bit REG28(R28,w28,clk);
adder_sub_block ASB29(R29,X[15:0]>>>9,~R26[15],w29);
reg_16bit REG29(R29,w29,clk);
adder_sub_block ASB30(R30[15:0],LUT9,R26[15],w30);
reg_16bit REG30(R30,w30,clk);
//11th stage
adder_sub_block ASB31(R31,Y[15:0]>>>10,~R29[15],w31);
reg_16bit REG31(R31,w31,clk);
adder_sub_block ASB32(R32,X[15:0]>>>10,~R29[15],w32);
reg_16bit REG32(R32,w32,clk);
adder_sub_block ASB33(R33[15:0],LUT10,R29[15],w33);
reg_16bit REG33(R33,w33,clk);
//12th stage
adder_sub_block ASB34(R34,Y[15:0]>>>11,~R32[15],w34);
reg_16bit REG34(R34,w34,clk);
adder_sub_block ASB35(R35,X[15:0]>>>11,~R32[15],w35);
reg_16bit REG35(R35,w35,clk);
adder_sub_block ASB36(R36[15:0],LUT11,R32[15],w36);
reg_16bit REG36(R36,w36,clk);
//13th stage
adder_sub_block ASB37(R37,Y[15:0]>>>12,~R35[15],w37);
reg_16bit REG37(R37,w37,clk);
adder_sub_block ASB38(R38,X[15:0]>>>12,~R35[15],w38);
reg_16bit REG38(R38,w38,clk);
adder_sub_block ASB39(R39[15:0],LUT12,R35[15],w39);
reg_16bit REG39(R39,w39,clk);
//14th stage
adder_sub_block ASB40(R40,Y[15:0]>>>13,~R38[15],w40);
reg_16bit REG40(R40,w40,clk);
adder_sub_block ASB41(R41,X[15:0]>>>13,~R38[15],w41);
reg_16bit REG41(R41,w41,clk);
adder_sub_block ASB42(R42[15:0],LUT13,R38[15],w42);
reg_16bit REG42(R42,w42,clk);
//15th stage
adder_sub_block ASB43(R43,Y[15:0]>>>14,~R41[15],w43);
reg_16bit REG43(R43,w43,clk);
adder_sub_block ASB44(R44,X[15:0]>>>14,~R41[15],w44);
reg_16bit REG44(R44,w44,clk);
adder_sub_block ASB45(R45[15:0],LUT13,R41[15],w45);
reg_16bit REG45(R45,w45,clk);
//16th stage
adder_sub_block ASB46(R46,Y[15:0]>>>15,~R44[15],w46);
reg_16bit REG46(R46,w46,clk);
adder_sub_block ASB47(R47,X[15:0]>>>15,~R44[15],w47);
reg_16bit REG47(R47,w47,clk);
adder_sub_block ASB48(R48[15:0],LUT14,R44[15],w48);
reg_16bit REG48(R48,w48,clk);
endmodule
//Pipeline Register
module reg_16bit(out,in,clk);
input clk;
input [15:0]in;
output reg [15:0]out;
always@(posedge clk)
begin
out<=in;
end
endmodule
module adder_sub_block(A,B,Cin,out);
input [15:0]A,B;
input Cin;
always@(Cin)
case(Cin)
1:out=A-B;
0:out=A+B;
endcase
endmodule
module stimulus;
reg [15:0] X, Y,Z;
wire [15:0] X_out, Y_out, Z_out;
reg clk;
initial
$monitor($time, "X_out = %b, Y_out = %b, Z_out = %b",X_out, Y_out, Z_out);
initial
begin
clk <= 1'b0;
#2000 $finish;
end
always #30 clk = ~clk;
initial
begin
X <= 33; Y <= 31; Z<=0;
end
endmodule
here is the output for the above code:
0X_out = zzzzzzzzzzzzzzzz, Y_out = zzzzzzzzzzzzzzzz, Z_out = zzzzzzzzzzzzzzzz
main.v:199: $finish called at 2000 (1s)
