My professor looked at this code for a good 10 minutes, but could not find the problem. So, I'm hoping a fresh pair of eyes will see something both of us missed. As always, I'll be grateful for any hints you can provide.
Context: A module that counts from FFF to 000, then repeats.
Problem: Only lowest 2 displays decrement, skipping several numbers at a time and then jump back up to FF at a seemingly random point.
Assumptions: 1. SevenSegment driver is working properly. It has been checked manually and will display the hex number it is given 2. The ClockDivider module works as intended. The countdown decreases every 1 second as it should (CLOCK_50 = 50 MHz)
Possible Hint: Verilog warns that "cd" is an inferred latch and retains its value through one or more paths in the "always" block
module ClockDivider( input CLOCK_50, output reg[ 31:0] count );
parameter clockDivisor = 50_000_000;
always @( posedge CLOCK_50 )
    if ( count == 0)
        count <= clockDivisor;
        else
            count <= count - 1;
endmodule
module Test (
    //////////// CLOCK //////////
    input                       CLOCK_50,
    //////////// SEG7 //////////
    output           [6:0]      HEX0,
    output           [6:0]      HEX1,
    output           [6:0]      HEX2
//ClockDivider Output
wire                [31:0]          cout;
reg                 [11:0]            cd;
ClockDivider a( CLOCK_50, cout);
always @(cout)
begin
if (cout == 32'h0)
        if (cd == 12'h0)
                cd <= 12'hFFF;
        else
                cd <= (cd - 12'h001);
end
SevenSegment    C2( cd[11:8],  1'b0, HEX2 );
SevenSegment    C1( cd[7:4],   1'b0, HEX1 );
SevenSegment    C0( cd[3:0],   1'b0, HEX0 );
endmodule
    \$\begingroup\$ You may be interested in this Stack Overflow question: What is inferred latch and how it is created when it is missing else statement in if condition.can anybody explain briefly? \$\endgroup\$
    – The Photon
    Commented Nov 7, 2015 at 5:46
  • \$\begingroup\$ As I see it the basic problem is you have cout in the sensitivity list, but it never appears in the r.h.s. of any of the assignments below it. So what can the tool infer except that you want to use cout as a clock signal for block. \$\endgroup\$
    – The Photon
    Commented Nov 7, 2015 at 5:48
  • \$\begingroup\$ @ThePhoton Thank you. So the program was using the least significant bit of cout as clock input. Glad you caught that one. \$\endgroup\$
    – Meridian
    Commented Nov 7, 2015 at 6:56
Personally, I have had problems with always @(cout) that can be flakey.
I would always use always @(posedge CLOCK_50) . In my opinion, you are guaranteed proper results this way...
EDIT: added clearer code for above suggestion
always @(cout) -> always @(posedge CLOCK_50)
cout should only change with the positive edge of the clock in theory (or code) but what is actually happening maybe different. Your timing report will tell you about setup time and slack - and this may be your problem. change your logic to all "synchronous" and I'll bet you it works.
also, get rid of the inferred latch as good practice. all this would take is an else statement:
if (cout == 32'h0)
    if (cd == 12'h0)
        cd <= 12'hFFF;
    else
else
    cd <= cd;
EDIT: suggested working code
module ClockDivider(input CLOCK_50,
                    output reg[ 0:0] en
    reg [31:0] i;
    always @( posedge CLOCK_50 ) begin
            if ( i == clockDivisor ) begin
                    en <= 1;
                    i <= 0;
            end
            else begin
                    en <= 0;
                    i <= i + 32'b1;
            end
    end
endmodule
//1Hz clock output
wire                [0:0]           en;
//Holds the countdown value FFF-000
reg                 [11:0]              cd;
ClockDivider CLOCK_1Hz( CLOCK_50, en);
    if (en) begin
        if (cd == 12'h0)
            cd <= 12'hFFF;
        else
    end
    else
        cd <= cd;
end
  • \$\begingroup\$ johnnymopo, thank you for your reply. The revised code still brought about an inferred latch (see ThePhoton above). And CLOCK_50 (50 MHz) would have been too fast for the countdown. But thanks to your suggestion of using posedge, I managed to figure it out. So wherever you are in this world, I wish the best of luck to you and thanks again for helping out a random stranger. \$\endgroup\$
    – Meridian
    Commented Nov 7, 2015 at 7:05
  • \$\begingroup\$ Just to be clear, adding else cd <= cd; still creates a latch; all you've done is make it explicit rather than implicit. In general, combinatorial latches created in this way should be avoided. \$\endgroup\$
    – Dave Tweed
    Commented Nov 7, 2015 at 12:01
  • \$\begingroup\$ @dave tweed, how would you write this to avoid a latch at all if you want to make synchronous logic with a common clock domain? cd has to be something.... I ask as I do this and it seems to work well, at least to 125 MHz where I've been working at. But I have no formal vhdl training. \$\endgroup\$
    – johnnymopo
    Commented Nov 7, 2015 at 15:16
  • \$\begingroup\$ @johnnymopo, I think your answer would be more clear if you included the always @(<xxx>) that you recommend. \$\endgroup\$
    – The Photon
    Commented Nov 7, 2015 at 15:43
  • \$\begingroup\$ Added code suggestion \$\endgroup\$
    – johnnymopo
    Commented Nov 7, 2015 at 18:38
Thanks to ThePhoton and johhnymopo I was able to figure out the solution. The solution was to have ClockDivisor act as a slower clock itself. The code becomes:
module ClockDivider( input CLOCK_50, output reg[ 0:0] count );
    reg [31:0] i;
    begin
            i <= i + 32'b1;
                    begin
                    count <= 1;
                    i <= 0;
                    end
            else
                    count <= 0;
    end
endmodule
In this case, this is a 1Hz Clock. The countdown decrement can then be triggered using the posedge of that slower clock:
//1Hz clock output
wire                [0:0]           slowClock;
reg                 [11:0]              cd;
ClockDivider CLOCK_1Hz( CLOCK_50, slowClock);
always @(posedge slowClock)
begin
if (cd == 12'h0)
    cd <= 12'hFFF;
else
end
  • \$\begingroup\$ Glad it worked. I would personally try to make it all work with one clock. I believe this would infer a new clock and on a larger design this could make timing more difficult. Could you post the exact inferred latch warning? \$\endgroup\$
    – johnnymopo
    Commented Nov 7, 2015 at 15:31
  • \$\begingroup\$ @johnnymopo The exact warning was: "inferring latch(es) for variable "cd", which holds its previous value in one or more paths through the always construct". \$\endgroup\$
    – Meridian
    Commented Nov 7, 2015 at 16:14
  • \$\begingroup\$ I wonder if this happens because slowClock is not a new clock domain in synthesis? if that were the case, cd changes once per second but still based on the 50 MHz clock, and hence, still a latch - but that seems weird. I still recommend using a common clock for all logic when possible. \$\endgroup\$
    – johnnymopo
    Commented Nov 7, 2015 at 17:51
