module round_robbin
parameter UNIT = 3,
parameter CH1_WT = 1,
parameter CH2_WT = 1,
parameter CH3_WT = 1,
parameter CH4_WT = 1,
parameter ADDR_WIDTH = 8,
parameter DATA_WIDTH = 8,
parameter CHANNELS = 4
input i_rt_lt,
input i_clk,
input i_rst_,
input [ADDR_WIDTH:1] i_addr [CHANNELS:1],
input [DATA_WIDTH:1] i_data [CHANNELS:1],
input [CHANNELS:1] i_wr,
input [CHANNELS:1] i_rd,
output reg [ADDR_WIDTH:1] o_addr,
output reg [DATA_WIDTH:1] o_data,
output reg o_wr,
output reg o_rd
typedef enum logic [$clog2(CHANNELS)-1:0] { CH1 = 2'b00,
CH2 = 2'b01,
CH3 = 2'b10,
CH4 = 2'b11} fsm_states;
fsm_states ps, ns;
reg [6:0] ch1_cnt;
reg [6:0] ch2_cnt;
reg [6:0] ch3_cnt;
reg [6:0] ch4_cnt;
always@(posedge i_clk or negedge i_rst_) begin
if(!_rst_)
ps <= CH1;
else
ps <= ns;
end
always@(*) begin
case(ps)
CH1:begin
if((ch1_cnt == (CH1_WT * UNIT)) && i_rt_lt)
ns = CH2;
else if((ch1_cnt == (CH1_WT * UNIT)) && !i_rt_lt)
ns = CH4;
else
ns = CH1;
end
CH2:begin
if((ch2_cnt == (CH2_WT * UNIT)) && i_rt_lt)
ns = CH3;
else if((ch2_cnt == (CH2_WT * UNIT)) && !i_rt_lt)
ns = CH1;
else
ns = CH2;
end
CH3:begin
if((ch3_cnt == (CH3_WT * UNIT)) && i_rt_lt)
ns = CH4;
else if((ch3_cnt == (CH3_WT * UNIT)) && !i_rt_lt)
ns = CH2;
else
ns = CH3;
end
CH4:begin
if((ch4_cnt == (CH4_WT * UNIT)) && i_rt_lt)
ns = CH1;
else if((ch4_cnt == (CH4_WT * UNIT)) && !i_rt_lt)
ns = CH3;
else
ns = CH4;
end
endcase
end
always@(*) begin
case(ps)
CH1:begin
o_rd = i_rd[1];
o_wr = i_wr[1];
o_data = i_data[1];
o_addr = i_addr[1];
end
CH2:begin
o_rd = i_rd[2];
o_wr = i_wr[2];
o_data = i_data[2];
o_addr = i_addr[2];
end
CH3:begin
o_rd = i_rd[3];
o_wr = i_wr[3];
o_data = i_data[3];
o_addr = i_addr[3];
end
CH4:begin
o_rd = i_rd[4];
o_wr = i_wr[4];
o_data = i_data[4];
o_addr = i_addr[4];
end
endcase
end
always@(posedge clk) begin
case(ps)
CH1:begin
ch1_cnt = ch1_cnt + 1;
ch2_cnt = 7'd0;
ch3_cnt = 7'd0;
ch4_cnt = 7'd0;
end
CH2:begin
ch1_cnt = 7'd0;
ch2_cnt = ch2_cnt + 1;
ch3_cnt = 7'd0;
ch4_cnt = 7'd0;
end
CH3:begin
ch1_cnt = 7'd0;
ch2_cnt = 7'd0;
ch3_cnt = ch3_cnt + 1;
ch4_cnt = 7'd0;
end
CH4:begin
ch1_cnt = 7'd0;
ch2_cnt = 7'd0;
ch3_cnt = 7'd0;
ch4_cnt = ch4_cnt + 1;
end
endcase
end
endmodule
module round_robbin_tb;
parameter UNIT = 6;
parameter ADDR_WIDTH = 3;
parameter DATA_WIDTH = 3;
parameter CHANNELS = 4;
reg i_rt_lt;
reg i_clk;
reg i_rst_;
reg [ADDR_WIDTH:1] i_addr [CHANNELS:1];
reg [DATA_WIDTH:1] i_data [CHANNELS:1];
reg [CHANNELS:1] i_wr;
reg [CHANNELS:1] i_rd;
wire [ADDR_WIDTH:1] o_addr;
wire [DATA_WIDTH:1] o_data;
wire o_wr;
wire o_rd;
round_robbin #(.UNIT(UNIT),
.ADDR_WIDTH(ADDR_WIDTH),
.DATA_WIDTH(DATA_WIDTH),
.CHANNELS(CHANNELS)
)DUT (i_rt_lt,
i_clk,
i_rst_,
i_addr,
i_data,
i_wr,
i_rd,
o_addr,
o_data,
o_wr,
o_rd
always i_clk = #1 ~i_clk;
initial begin
$dumpfile("round_robbin.vcd");
$dumpvars("0,round_robbin_tb");
i_rt_lt = 0;
i_clk = 0;
i_rst_ = 1;
i_addr[0]=2;
i_addr[1]=4;
i_addr[2]=5;
i_addr[3]=6;
i_data[0]=4;
i_data[1]=6;
i_data[2]=5;
i_data[3]=1;
i_wr=$urandom;
i_rd=$urandom;
#5;
i_rst_=0;
#3;
i_rst_=1;
#100;
$finish;
end
endmodule
iverilog -g2005-sv -pfileline=1 -E round_robbin.sv round_robbin_tb.sv -Wall
I have no errors in using the above command.
After that, I used vvp a.out
, then I get this error message:
a.out 1:syntax error
Can anyone help me?
a.out
? ... your source files have names starting withround_robbin
... the module also has that same name \$\endgroup\$iverilog
command generates a file nameda.out
when the-o
option is not used. \$\endgroup\$
